Inventor Forum
chamfer complex condition
2 REPLIES 2
marcusfriesl
577 Views, 2 Replies
I hope this is the right place to ask.
I have only being using Inventor 2014 now for a week or so and I am trying to add a chamfer between a leg and a table top.  The transition between the leg and the top is a radiused corner.  The leg and top are one solid.
Below is the edge that needs to be chamfered.
I have tried to create the chamfer after the radius and before, and the result is either an error or some weird chamfered disjointed result.  I only need to chamfer it 5mm.
I have attached the working file in inventor 2014 format below.  Any help would be greatly appreciated.  I would like to find out what I am doing wrong.
Tags (3)
2 REPLIES 2
MingweiGao
in reply to: marcusfriesl
I just found there are some discontinuous edges between the legs and the top. It may be caused by the loft feature. If you create the chamfers(5mm) firstly, you will see there is a noncoincidence region between the two chamfers, please refer to the attached pictures. Based on my understanding of your design, the outer face of legs should be the same with the table(if not, please correct me). So I tried to use DELETE FACE command with HEAL option to delete the outer faces of legs and then added the fillets and chamfers. Refer to the attached part.
Steven Gao
Sr. SQA Engineer
marcusfriesl
in reply to: MingweiGao
THank you.  That works perfectly.  How did you search for the noncoincidence regions?
Thanks for responding so quickly.
