Hi! The way chamfer computes is quite similar to fillet. Typically, an edge on a solid has two adjacent faces. When it is selected for chamfer, Inventor will compute the chamfer boundary on each adjacent face by offsetting the selected edge loop in assigned distance on the adjacent face. Once the boundaries are defined, the chamfer face can be obtained.
To prove my point. You can simply do this experiment.
Move EOP above the chamfer.
Create a 3D Sketch->include geometry->pick the chamfer edge->finish.
Move EOP to the bottom.
Create a workpoint (A) by selecting the 3D Sketch and YZ plane.
Create a workpoint (B) by selecting the chamfer boundary edge (top) and YZ plane.
Create a workpoint (C) by selecting the chamfer boundary edge (bottom) and YZ plane.
The distance between A and B should be 0.5mm as is the distance between A and C.
The same test can be performed on XY plane.
Let me know if you have any question.
Thanks!
johnson.shiue@autodesk.com
Software Test Engineer
