Dave,
Thanks for your help and input. I was hoping to hear: Yeah, we have done
that, here is the Macro !
No, we didn't use (your link) for parts. We created our own components.
I tried using the one you mentioned. I can't get the excel notes
to update the drawing.
I enter:
#40 chain
72 teeth
50 teeth
127" center-to-center
I get the following error: WARNING, Cell B54 MUST be 2 or Greater, adjust
above B54 =
How do get rid of the error?
And how do I get the table to update the ipt file?
Peter
peterd@bigskyeng.com
"Dave J" wrote in message
news:B5B06A461635B19D604637CFE9A5B871@in.WebX.maYIadrTaRb...
> First of all, moving chain around a sprocket correctly is, for all intents
and
> purposes, impossible at this point. I have a method that allows harmonic
motion,
> but nothing like you want. (Believe me, I've tried)
> Second, right now there is no such thing as Assembly iParts. You can drive
all
> the parameters using a spreadsheet though.
> Example: Did you use this chain for Parts (not iParts):
> http://www.cbliss.com/inventor/Parts/RollerChain.zip?
> With this, it will automatically create the chain at the correct C.D.,
sprocket
> diameter and pitch. You can then constrain the sprockets to the middle
plane of
> chain loop, C/L of one of arcs, and c/l of one of the chain rollers. If
you need
> a configuration where 1 chain goes around more that 2 sprockets, you will
have
> to just constrain the chain rollers (used from iPart) to the individual
sprocket
> teeth (just the ones that are completely in the teeth)
> Dave Jacquemotte
> Automation Designer
