Only tangentially connected edges will be automatically chained.
You will have to manually select each edge in the same instance of the
Chamfer tool, but they will all be grouped in the same chamfer feature.
Once all edges are selected and chamfered, it is easy to go back and simply
change one value to control the entire edge set.
wrote in message news:4912576@discussion.autodesk.com...
I have several edges that need to be chamfered, all with the same
parameters. IV will only allow me to chamfer one edge at a time, as far as
I can tell. I want to link the chamfers together so that if I change one of
them, they all change. How?
