Inventor General Discussion
New Member
alanbailey1
Message 1 of 3 (285 Views)
.CFG files for Wiring
285 Views, 2 Replies
11-29-2012 07:21 PM
I can't seem to find the .cfg files that supposedly come with autocad Inventor to manipulate and export wiring information.  I've done a complete search of all my autodesk folders but it just doesn't seem to be anywhere.
Is there a place online where this file is mirrored and can be downloaded or copied?
Alan
Curtis_Waguespack
Message 2 of 3 (279 Views)
Re: .CFG files for Wiring
11-29-2012 08:58 PM in reply to: alanbailey1
Hi alanbailey1,
I think you'll need to download the sample files to find an example *.cfg file:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=13923228&linkID=9242019
Once downloaded look for a sample at some path such as this:
...\Inventor 20xx\Cable & Harness\Samples\Wire List Import
I don't have the exact path in front of me at the moment.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Active Contributor
jonathanruffray
Message 3 of 3 (248 Views)
Re : .CFG files for Wiring
12-03-2012 04:40 AM in reply to: alanbailey1
Hello Alan,
Are you not looking for your wires and harness library with list all yopu cabkle components?
In this case you should search for an *.iwl files and not *.cfg. It should be
../Design data/Cable & Harness/fr-FR/Cable&HarnessDefaultLibrary.iwl
You have to replace "fr-fr" by your localization....
John.
Autodesk Product Design Suite Ultimate 2013
Win 7 Pro 64 bits SP1
Bi-Xeon E5520 (2x Quad-core @2.27GHz)
Quadro Fx 1800 768Mo GDDR3
6Go Ram DDR3 667MHz ECC
