Hello All.
I am new to this forum and still new to Invventor. This is in an Inventor Drawing. I have a vessel with nozzles that are not normal, or perpendicular, to the outside shell of the vessel, theyt are more tangential. I would like to place a cenerline from the center of the vessel to the point where the centerline of the nozzle intersects the wall of the vessel. Can anyone please help.
Solved by mrattray. Go to Solution.
Hello and Welcome!
Can you include a screen shot of some sort, showing what it is you'd like to do? Hard to tell from just the description.
Also, as a welcome note: it's always a good idea to mention the version of software you use, and (especially for system issues) your system specs. A lot of people put this stuff right in their signatures. Screen shots or attached files are always helpful, depending on the question. Good luck!
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thank you
I have attached a small screen shot. You will see I have a centerline on the nozzle but I cannot snap a centerline from the center of the vessel to anything. If it were perpendicular this would be easy but as you can see the nozzle is at an angle.
Unfortunately the centerlines in Inventor's drawing mode leave, well,.... a lot to be desired. Enhancements to this are a common request.
You could always sketch these on the draiwng, but they will not update if your tank changes. Not the best or most elegant solution, but it would get it done.
You could also edit your Centermak style in the Styles Manager (Manage Tab) and set the overhang dimensions to .001 so that it appears the centerline is right on the OD of the tank, might get the two centerlines closer to an appearance of intersecting.
Chris Benner
That worked. It is exactly what I wanted.
What I was trying to acomplish is to locate that nozzle at an angle from the vessel centerline at the point where the centerline of the nozzle and the vessel wall meet. Just like in the screen shot I posted. This was a good idea. I had a work plane for the elevation of the nozzle and I had a work plane for the rotation of the nozzle from the vessel centerline, I just put a work plane at the intersection of those 2 planes and included it and it appeared and I was even able to change the length of it so it was not so long.
Thank you very much.
