Inventor General Discussion
*Fred Payne
Message 1 of 9 (445 Views)
Center point visibility : dwg import
445 Views, 8 Replies
09-17-2009 01:12 PM
I imported some dwg blocks into Inventor with the
idea that I use them in conjunction with other parts in an
assembly.
Having done so, I can't hide the center points. Any
suggestions? Am I missing something obvious? See attached view.
I need a cure for imeasles.
Lawrence
IV series 2010
Employee
ralfwalter
Message 2 of 9 (445 Views)
Re: Center point visibility : dwg import
09-21-2009 10:15 AM in reply to: *Fred Payne
There currently is no way to supress the visibility of the sketch point geometry but we are looking into the issue. Thank you!
Ralf Walter (Autodesk)
*Fred Payne
Message 3 of 9 (445 Views)
09-21-2009 10:48 AM in reply to: *Fred Payne
OK. Thanks. I got a lot of work to do then recreating.
regards .............. Spotty Muldoon Esq.
"ralfwalter" wrote in message news:6257767@discussion.autodesk.com...
Active Member
mwittendorp
Message 4 of 9 (344 Views)
10-24-2012 01:02 AM in reply to: *Fred Payne
I got the same issue here, and i wonder if there is already a solution for this problem. (because the thread is from 2009). I'm using inventor 2013.
Valued Contributor
michael.marx
Message 5 of 9 (295 Views)
02-04-2013 04:51 AM in reply to: ralfwalter
i also get into the same issue
is there something done meanwhile?
JDMather
Message 6 of 9 (286 Views)
02-04-2013 07:40 AM in reply to: michael.marx
You could set Tools>Application Options>General tab to a real small value on Annotation Scale to make them less visible, but this will also make sketch dimension annotations very small.
http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
Valued Contributor
michael.marx
Message 7 of 9 (283 Views)
02-04-2013 07:44 AM in reply to: JDMather
Thank you for the input but that´s not what i´m searching for
JDMather
Message 8 of 9 (278 Views)
02-04-2013 08:04 AM in reply to: michael.marx
No.
New Member
MARCDOSSANTOS
Message 9 of 9 (226 Views)
04-03-2013 04:38 PM in reply to: *Fred Payne
I just found that by going to properties for the sketch into which you've imported the ACAD drawing, you can change lineweight and all the points become far less prominent.
