Inventor Forum
Center of gravity?
8 REPLIES 8
Message 1 of 9
rutan
522 Views, 8 Replies
Center of gravity?
I have a center of gravity question.
How does one locate the center of gravity on a part? I can get the xyz coords from properties for the center of gravity once my material is selected, but how do I translate that to the actual part?
Is there a symbol or some other identification that would actually show where the center of gravity is on the model or is this something that is detailed in the IDW? Note, we are not ready to detail yet, but are trying to pass on some information to engineering as to where the CG is located.
If there is another thread that speaks to this issue, point me in that direction.
thanks,
john
CAD Supervisor
Atlas Copco Compressors Inc.
8 REPLIES 8
Message 2 of 9
jiml
in reply to: rutan
go to cbliss.com download vba cog program
Message 3 of 9
in reply to: rutan
There is a center of gravity tool but it won't
propagates to the IDW.  The way you can do it is to get the COG from the
properties menu and the use a grounded workpoint and start at the origin and
enter the x,y,z offsets.  This places a workpoint at the COG.  Then in
the IDW you can check the option (get workfeatures) and the workpoint will show
up.
This does not dynamically update
however.
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
...sleep is for the
weak..
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
direction.
thanks,
john
CAD Supervisor
Inc.
Message 4 of 9
in reply to: rutan
Jim this tool is built into R6 on the View
menu.
Sean Dotson, PE
...sleep is for the
weak..
go
Message 5 of 9
jiml
in reply to: rutan
opps thought I was in 5.3 news group
Message 6 of 9
in reply to: rutan
Would also be nice if the COG in R6 updated as you
drive a constraint....
Brian
in the IDW you can check the option (get workfeatures) and the workpoint will
show up.
however.
Sean Dotson, PE
...sleep is for
the weak..
I
direction.
thanks,
john
CAD Supervisor
Inc.
Message 7 of 9
in reply to: rutan
Try to find out when that part will fall of the
cliff are you? <g>  That would be nice.  I'd also like it to be
able to be shown directly in the IDW (and hence it would update)
Sean Dotson, PE
...sleep is for the
weak..
you drive a constraint....
Brian
the properties menu and the use a grounded workpoint and start at the origin
and enter the x,y,z offsets.  This places a workpoint at the COG.
Then in the IDW you can check the option (get workfeatures) and the
workpoint will show up.
however.
Sean Dotson, PE
...sleep is for
the weak..
I
direction.
thanks,
john
CAD Supervisor
Inc.
Message 8 of 9
in reply to: rutan
Actually Sean yes ;-)...
I just went thru the exercise of design a tipping
trailer and Neils COG tool for 5.3 was a god-send, but it would be nice to see
it dynamically update thru the motion. Even just a tick box in drive constraints
to turn that feature on and off would be great....
Brian
be able to be shown directly in the IDW (and hence it would
update)
Sean Dotson, PE
...sleep is for
the weak..
Brian
won't propagates to the IDW.  The way you can do it is to get the COG
from the properties menu and the use a grounded workpoint and start at the
origin and enter the x,y,z offsets.  This places a workpoint at the
COG.  Then in the IDW you can check the option (get workfeatures) and
the workpoint will show up.
however.
Sean Dotson, PE
...sleep is
for the weak..
I
is located.
that direction.
thanks,
john
CAD Supervisor
Inc.
Message 9 of 9
rutan
in reply to: rutan
To all that replied, thanks for the input. Shortly after I posted, our VAR called and we got a few tips from him and were able to figure it out using workpoints.
But as others have indicated, it would be nice if this feature were available when creating an IDW and it would be even nicer if it updated with the part.
Possible wish list item?
Anyway, thanks for the help.
john
