Inventor Forum
Center Of Gravity question
7 REPLIES 7
Message 1 of 8
GavinReynolds2021
580 Views, 7 Replies
I am trying to pinpoint the center of gravity on a curved face of an assembly. I can use the c og G command to get the true center of gravity but i would like to incorporate lifting eyes into the finished assembly. Basically I need to know how to find the C of G on a given surface. I have attached the assembly I am working on and added lifting eyes roughly where I would like them. I have tried measuring from the C of G to a face and then creating the lug above the C of G but somehow it dosent line up.
Any help is appreciated.
Thank you
Gavin
7 REPLIES 7
Message 2 of 8
An assembly file (*.iam) is only a list of hyperlinks to the part files (*.ipt) and a record of assembly constraints (and a bit more).
You must include the part files.
Message 3 of 8
Thanks for helping me out again. I apologise for my incompetence but this is
a big jump for me to inventor and its tough going with no classes available
here. Working hard to learn as I go.
I have attached the part files.
Regards
Gavin Reynolds
Celtic Power & Machining
Tel. 204.826.2660
Cel. 204.720.0997
Fax. 204.826.2734
www.celticpower.ca
Message 4 of 8
Do you see the attachments?
Message 5 of 8
I hit reply and attached to the return email so I assume you didnt see them. I will attach them here in the forum in a couple of posts
Message 6 of 8
Message 7 of 8
Message 8 of 8
Did you rename files?
Your assembly file is a hyperlink record to the part files.
If you rename the files - the hyperlinks are broken.
