Also, remember to update the propertys.
wrote in message news:5219141@discussion.autodesk.com...
I am creating an assembly of a tiltbed truck trailer, and I need to find its
center of gravity. I know I can go to the Physical tab of the iProperties
and update its COG there, but when I did that, I got some unexpected
results.
Actually, the COG is basically where we expect it to be (about the center of
the bed), but we want to make sure that it's reliable. To test it, I put a
huge steel i-beam in the assembly, and constrained it on the back of the
bed. I expected this to move the COG waaay back on the trailer, but it only
moved about an inch. This was a 14-inch i-beam, it should have moved more
than that. Is there something I'm missing? Most of the parts I'm using for
this are the standard Inventor content center structural steel parts
(c-channel), and for the parts I created myself, I made sure they all had
the correct material designations (all steel). Shouldn't I get an accurate
reading of my assembly's COG, or am I forgetting something?
Any help is greatly appreciated.
