Yes I have use that for other purposes, but not for a bolt circle.
"Larry Caldwell" wrote in message
news:820A225C261A13E5062DD4C76C159A9C@in.WebX.maYIadrTaRb...
> The centerline bisector Kent mentioned is normally used for bolt patterns,
> have you already tried that? The icon is like two angled lines and an arc.
> ~Larry
> "Herb Morrison" wrote in message
> news:5CECF534A71345BBAEBA3CECAEC44B0F@in.WebX.maYIadrTaRb...
> > Its in an idw, it is the a large bore hole with a bolt pattern around
it.
> I
> > used the center mark tool and extended the center lines.
> > I found a work around.
> > "Kent Keller" wrote in message
> > news:E4777FF24D01FB64E35A0BC17D6F8E3D@in.WebX.maYIadrTaRb...
> > > This is in a IDW right? What is the centerline a centerline for? can
> you
> > use a bisector
> > > centerline or one of the other ones rather than sketching one in?
> > Actually you don't even
> > > say how you created the centerline?
> > > Kent
> > > Assistant Moderator
> > > Autodesk Discussion Forum Moderator Program
> > > news:1AB4A8E8EB318F0E4656F4363BF59F92@in.WebX.maYIadrTaRb...
> > > > When putting in a centerline, I can edit the line and get it to
align
> > with
> > > > an edge. This is good. Now if I use that centerline to create a
> > dimension,
> > > > say an angle to a hole, the centerline looses its alignment to the
> edge.
> > I
> > > > can go back and edit the centerline and align it to the edge again,
> but
> > what
> > > > ever I do to the dimension will cause the centerline to loose its
> > alignment
> > > > to the edge. Is there a fix? (Or, sarcastically, do I have to by
> Pro?)
