Inventor General Discussion
Valued Mentor
graemev
Message 1 of 5 (239 Views)
CC parts saved as custom not updating thumbnails
239 Views, 4 Replies
03-26-2013 11:08 AM
When inserting a Content Center part into an assembly as a custom part instead of as a standard one, then opening and modifying the part, the thumbnail for the new file is not updating to show the modifications.  In this particular instance: a pipe blind flange with an off-center hole drilled through the face.  The thumbnail still shows as the original (and fairly pixelated) CC blind flange.
Any suggestions on forcing the thumbnail to update?
Go to iproperties go to the save tab
change to Active window hit capture then hit apply then change back to Active Component iso view on save hit apply again and close. Thumbnail should update.
*Pro
ampster
Message 2 of 5 (235 Views)
Re: CC parts saved as custom not updating thumbnails
03-26-2013 11:21 AM in reply to: graemev
what is set in iProperties > Save tab?
*Pro
jletcher
Message 3 of 5 (224 Views)
03-26-2013 11:46 AM in reply to: graemev
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
*Pro
ampster
Message 4 of 5 (218 Views)
03-26-2013 11:53 AM in reply to: jletcher
pft, why give them the fish!
Show em where it's at and let them figure it out!
Valued Mentor
graemev
Message 5 of 5 (205 Views)
03-26-2013 12:51 PM in reply to: jletcher
Actually, "Active Component Iso View on Save" alone works fine for my needs.
Thanks!
