Inventor General Discussion
Valued Contributor
390 Kudos
Post 1 of 8
CC Feature
258 Views, 7 Replies
07-16-2012 05:08 AM
Can´t place CC feature anymore in R2013 is this a bug?`
regrads Michael
Active Contributor
3 Kudos
Post 2 of 8
Re: CC Feature
07-16-2012 02:14 PM in reply to: michael.marx
Have you checked your Default Content Center path for your current Project?  at Inventor Application Menu > Manage > Projects > Your active Project > Lower Pane Project > +Folder options drop down  > highlight, Content Center Files = [Default]  left click Select Browse For Folder and set to where your Content Center Folder are located. If true then maybe you need to set your Default Content Center files location. Go Tools > Options > Application Options File panel 4 frames down to > Default Content Center files > Browse For Folder to where the Content Center folder is located in your installation, %USERPROFILE%\Documents\Inventor\Content Center Files\R2013\.  If installed. Or you may you need to set your Location of Libraries: at Tools > Options tab > Application Options > Content Center tab > Libraries: > Browse For Folder, folder > to where your Content Center folder is. Something like “C:\ProgramData\Autodesk\Inventor 2013\Content Center\Libraries”
Yours truly
Carl T.
Valued Contributor
390 Kudos
Post 3 of 8
Re: CC Feature
07-16-2012 10:45 PM in reply to: michael.marx
Hi Carl,
thank you for your explanation but i think my question wasn´t clear enough. :-)
I have the CC feature for selection in the CC database but if i try to put in a feature in a part, inventor want a face and then nothing happens.
Michael
Active Contributor
3 Kudos
Post 4 of 8
Re: CC Feature
07-17-2012 06:25 AM in reply to: michael.marx
I am sorry that I jumped to the incorrect conclusions about why you are not able to place a Content Center feature.  I have placed a Content Center features and bolted Connections in an Assembly and Part files with Autodesk Inventor Release 2013.  Therefore I can say that I do not think that it is a bug! Have you tried to place a Content Center feature in an Assembly file?
Yours truly
Carl T.
Valued Contributor
390 Kudos
Post 5 of 8
Re: CC Feature
07-19-2012 05:12 AM in reply to: freegoodkharma
Hi Carl,
CC feature isn´t avaiable in asm CC parts are there!
in the pictures beside is what i mean. CC content is visible and pickable but not set able :-)
Michael
Active Contributor
3 Kudos
Post 6 of 8
Re: CC Feature
07-19-2012 06:39 AM in reply to: michael.marx
If after selecting the feature, the feature specks, a face, the feature position with arrow grips.  Does your mouse pointer arrow have a plus sign next to it, if so have you tried right clicking and selecting, done, or the move and position options or cancel.
Yours truly,
Carl T.
P.S Of course you can place Content Center features in an Assembly.  In and assembly go Assemble tab > Component tab > Place from Content Center > to the features dropdown.  Select and place. Rem right click then Done.
New Member
1 Kudo
Post 7 of 8
Re: CC Feature
07-25-2012 07:17 AM in reply to: michael.marx
you must change comma with dot in custom format options of windows localization
regards
New Member
0 Kudos
Post 8 of 8
Re: CC Feature
10-08-2012 03:20 AM in reply to: ezio.grasselli
regards
thanks a lot! It works!
Regards from germany
Michael
