We have a studded bolt that we created with a bunch of different sizes.
I had to delete it out of the CC and make some changes to it. In the mean time there
were some of these bolts already checked into the vault into the CC portion because of their
usage on various assemblies.
I have since made the changes and now when I try to swap out one particular bolt size it gives me this
error message. Can some please explain to me where I can find these so called otther family in the CC
files location?
Solved by Cadmanto. Go to Solution.
Try opening one of the assemblies, then open the content center part and do a save as, you will be able to see where it is saved.
Thanks John.
What I ended up doing was moving the CC parts from my local to a network drive.
When I did that I was able to swap out the part with out an issue. I am marginally surprised that
this tripped up the software instead of allowing it and just replacing what was already prexisting on the hard drive
with the new from the updated CC.
