Dear all,
I have an issue with files that are checked out to users in an old shared workgroup. These parts have now been added to vault into a library. As a result Vault/Inventor was quite happy to add the files to vault as the library is read-only and therefore the file(s) being reserved was not a problem.
Now when I use these files in Inventor I have various refresh errors relating to the library files. But because the files are reserved in the old sense I cannot edit them and check them back in. In fact I can't check them out in the first place even using a vault project within the library.
So, my support guy gave me a plan to follow. I have a shared (non-vault) project on my local machine where the vault library working folder is. I get all the library files then individually open and steal check out and/or check in. Then with my vault project I can check those files back into the vault.
The issue is I have thousands of affected files.
I found the cbliss unreserve tool as recommended by many other users. Bingo I thought! However it doesn't appear to work with this release. Has anyone had any success with the tool in 2014? Or, does anyone know of any other quicker method I can adopt?
Many thanks
Ross Hollands
Ross,
Are you an administrator to your vault? If you are, seems to me like you should be able to move these parts out of the library folders and change the permissions of them as an administrator. At my last company, we were steered away from using libraries and told publishing these types of parts to the was a better avenue to follow. Can you post some screen shots of what these parts look like in the vault and the restrictions on them currently?
I would also add that while I am aware of cbliss as a site to download various inventor model parts from, I have only downloaded one or two parts from there.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Thank you for your reply Michael, your suggestion is similar to that provided by my support reseller.
I was hoping to find a multi-file alternative.
Thanks again.
Ross
Hello Scott,
Yes I am admin.
In your reply you missed a work in the sentence:
"At my last company, we were steered away from using libraries and told publishing these types of parts to the "?????????" was a better avenue to follow. "
What did you mean to say where I have added "??????". Thanks.
I'll try what you suggest and see if that is a smoother route compared to my other oprion.
Thnaks
Ross
Oh, I typed it, the problem is I am working on a laptop that can't keep up with my typing speed and if I don't catch it, things like this happen
Anyway, the "??????" was supposed to be "CC" or "Content Center".
Sorry about that!!!
Ha ha! No problem. Thanks for that. The files in question aren't really suited to CC but thansk for the suggestion.
I'll try your suggestion shortly and get back to you.
Kind regards
Ross
Yeah, if the are assemblies then they can't go into the CC. I still remember our VAR saying we were better off creating our own sub folders for library types of parts. and to stay away from libraries. I wish I could remember why.
Right now I do not have access to Vault or I would try and bring a better resolution to your issue. That is why I was hoping you could provide some images. Since you are an administrator, have you tried taking a couple of these files and moving them, then trying to change the permissions on them?
Do you know how to release ownership of a file that is checked out by another?
I'll try it shorlty and send images.
I know how to release ownership when logged in as admin. Problem is the files do not appear to be checked-out in vault. Only when I'm in Inventor do I see the problem. The giveaway was that the files are for example checked out to user RAH (uppercase). In vault we are all lower case i.e. rah. The uppercase is from the old shared workgroup. So from within the vault I don't think I can release the files...?
Hi Scott,
I 'got' all the library onto my c drive working folder. Using the cbliss tool I identified that file '7-030SS (stainless jubilee clip).ipt' was reserved by ARM.
I moved this file out of the library and into a normal folder.
I logged in as admin.
I navigated to the file and attempted to remove reservavtion. I got the attached message!
I am starting to think that the solution provided by my reseller is the only way. It would appear that shared workgroup check out is NOT considered the same as vault check out.
I'm willing to try other solutions if you have any.
Ross
I am glad you at least found something that works for you. Seems pretty simple.
Sounds like you were left with this daunting task of cleaning someones elses mess?
If that is the case, good luck to you.
Yeah that's almost true but I have to take overall responsibility! The fairly frustrarting thing I found is that vault will allow the files in in the first place but when you think about it a library wants read-only files so I guess it's right to allow them in without a fuss!
Thanks again.
Saying that is making me reflect on these might be the reasons my VAR was trying to steer us away from using the libraries.
We ended up creating standard folders. Folders that had permissions on them and only admins like myself could access to edit. This saved all of the headaches you are going through. Not to mention like you have stated, by getting parts from cbliss has opened up a whole new set of issues.
If I were you as you go through these, I would place them in non-library folders and set them up like I described.
The reserved flag is extended-entity data that's added to the file. It's acually visible somewhere in the iProperties dialog box if I remember correctly.
Getting rid of it is a real pain without a utility for some sort.
Autoloader strips all that baggage - but it means you'll have to re-load all the files again. If you are tempted, then follow Cadmanto's advice about setting permission by user - not by locking the entire folder. Reason, logic, and explanation are given here:
http://designandmotion.net/autodesk/vault/project-file-libraries-vs-vault-library-folders/
