Inventor Forum
CB inside of CB- idw bug-
2 REPLIES 2
103 Views, 2 Replies
Fairly simple round part, with a hole feature--CB .55dia x 1.00 dp x .067
thru, on the face of the .55 cb i've got another CB .104 x .1 dp x .067
thru, in the idw when you use hole note on the smaller inside cb... the hole
note always shows the bigger outer cb, even though the arrow is clearly
attached to the .104 cb.... I've tried multiple methods trying to get it to
show the accurate dim for the smaller cb with no luck. I've posted the file
to CF. I think this is a bug, has anyone else seen this before, or can
confirm this..
Brian Land
Mechanical Design
Lorik Tool Inc.
2 REPLIES 2
I think the reason is that the smaller CB isn't normal to the view plane. I
usually use a section view and a linear diameter dim in a case like that.
The idw is still just a view of the 3D model (as opposed to lines projected
to the view plane), but only showing the face you chose to show. If you
could rotate the sheet and peek behind it you would see the whole model
sucked-up to the view plane ... (don't know where the hide the vacuum pump
though ).
~Larry
"Brian Land" wrote in message
news:9C6CA53A90D38A9AE4A8B041708F26C6@in.WebX.maYIadrTaRb...
hole
to
file
> confirm this..
> Brian Land
> Mechanical Design
> Lorik Tool Inc.
Oops ... forgot ... you can use a break-out view if you want the hole note I
think.
~Larry
hole
to
file
> confirm this..
> Brian Land
> Mechanical Design
> Lorik Tool Inc.
