I think the reason is that the smaller CB isn't normal to the view plane. I
usually use a section view and a linear diameter dim in a case like that.
The idw is still just a view of the 3D model (as opposed to lines projected
to the view plane), but only showing the face you chose to show. If you
could rotate the sheet and peek behind it you would see the whole model
sucked-up to the view plane ... (don't know where the hide the vacuum pump
though ).
~Larry
"Brian Land" wrote in message
news:9C6CA53A90D38A9AE4A8B041708F26C6@in.WebX.maYIadrTaRb...
> Fairly simple round part, with a hole feature--CB .55dia x 1.00 dp x .067
> thru, on the face of the .55 cb i've got another CB .104 x .1 dp x .067
> thru, in the idw when you use hole note on the smaller inside cb... the
hole
> note always shows the bigger outer cb, even though the arrow is clearly
> attached to the .104 cb.... I've tried multiple methods trying to get it
to
> show the accurate dim for the smaller cb with no luck. I've posted the
file
> to CF. I think this is a bug, has anyone else seen this before, or can
> confirm this..
> Brian Land
> Mechanical Design
> Lorik Tool Inc.
