Inventor General Discussion
METZ150MX
Message 1 of 11 (211 Views)
capacity meter always spiking!!
211 Views, 10 Replies
03-13-2012 12:13 PM
anytime im working in a assembly with multiple parts my capacity meter goes into yellow and when i put it on paper it goes into the red....   my assemblies cant be near as big as other users of this program... is there something i may be doing wrong???  or could it be my computer isnt got enough memory or something?
METZ150MX wrote:
can i do the 3g switch with windows vista?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9583842&linkID=9240697
and follow their recommendation for the 3072 userva and if you have problems try to lower it some.
Cadmanto
Message 2 of 11 (209 Views)
Re: capacity meter always spiking!!
03-13-2012 12:18 PM in reply to: METZ150MX
What are your computer specs?
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
METZ150MX
Message 3 of 11 (206 Views)
03-13-2012 12:24 PM in reply to: Cadmanto
under system:
manufacturer: dell
model: precision pws490
rating: 4.7 windows experience index
processor: intel(R) cpu   5160 @ 3.00 ghz  2.99 ghz
memory (ram): 4.00gb
system type: 32-bit operating system
Cadmanto
Message 4 of 11 (203 Views)
03-13-2012 12:41 PM in reply to: METZ150MX
Based on what the Autodesk system requirements are that doesn't look too bad.
What OS are you running?  What version of Inventor and SP are you running?
Best Regards,
Scott McFadden
mcgyvr
Message 5 of 11 (189 Views)
03-13-2012 01:25 PM in reply to: Cadmanto
Thats why most of us have 64 bit systems now..No limit on the amount of RAM you can have (if you motherboard can support it).
With my 64 bit system using Inventor I'm constantly using 4-6 Gigs of RAM for Inventor alone. (you have at most 2G available for Inventor with a 32 bit OS..
When I had a 32 bit system I was in the yellow/red most of the time too. The way to free it up is to close Inventor and reopen it. Inventor keeps files in memory even after you close the file. But when you restart Inventor it frees up that memory.
You can enable the "3G switch" (google it) which will help some (setting a USERVA of 2800 seemed to be good)
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
jtylerbc
Message 6 of 11 (181 Views)
03-13-2012 01:32 PM in reply to: METZ150MX
Check into your virtual memory settings - if you're running into this problem on just a handful of parts (assuming the parts aren't really complex), they may just be set too low.
If that doesn't get you where you need to be, 64 bit Windows is the ultimate solution, and the 3 GB switch is a decent workaround for 32 bit.
John Tyler
Inventor 2015
Windows 7 64 Bit
Cadmanto
Message 7 of 11 (164 Views)
03-13-2012 06:01 PM in reply to: METZ150MX
I would have to say I agree with what has been said.  I run on a 64 bit machine using 12GB of memory
and opening large assemblies.  Depending on how large your files are and your system specs, while they are within the limits of the autodesk basic specs, usually what they specify are the bare minimum.  Just enough to run it.  So with that said I would not expect brilliant results.
Best Regards,
Scott McFadden
METZ150MX
Message 8 of 11 (143 Views)
03-14-2012 05:36 AM in reply to: METZ150MX
ok i will try the 3G switch and thanks for the responses
METZ150MX
Message 9 of 11 (140 Views)
03-14-2012 05:49 AM in reply to: METZ150MX
mcgyvr
Message 10 of 11 (132 Views)
03-14-2012 06:09 AM in reply to: METZ150MX
Windows 7 64 bit
