Hello
I use alot "Export to DWG" for our machineshop but suddenly it doesnt work!
I get only this warning when trying to export
Do anyone have a tip on what to do?
Solved by Curtis_Waguespack. Go to Solution.
Hi Mustang69,
It looks like you are using Inventor 2013, but this link speaks to the same (or similar) issue with Inventor 2014, so it might be worth a try:
I hope this helps.
Curtis
Thankyou it worked just fine!!
I recently tried some of Autodesk "Exchange APPS"
Could these apps been the cause of the problem?
Never had it before.
