Inventor Forum
cant rotate second open file with space pilot
3 REPLIES 3
hosford
361 Views, 3 Replies
using a space pilot and inventor 2014, cant rotate but the first file open, have to close first to rotate second file
got any ideas?
inventor 2014
Thaddeus Hosford
NUC9i9QNX i9-9980HK, Win 10 Pro 64
Nvidia GTX 1650
Inventor 2021
3 REPLIES 3
CCarreiras
in reply to: hosford
Hi!
For me works well... Try to update the space pilot driver.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
blair
in reply to: CCarreiras
Reboot the system, sounds like a driver might not have loaded properly. It wouldn't hurt to make sure you are on the latest drivers as mentioned.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
hosford
loaded new driver wich forced a reboot, so it could have been the driver, or just needing a reboot.
Thaddeus Hosford
Nvidia GTX 1650
Inventor 2021
