Inventor Forum
cant open inventor 2011 undo folder message
16 REPLIES 16
Message 1 of 17
5461 Views, 16 Replies
when i try to open my 2011 inventor program which ive been running for months now i get an error message. and the program refuses to open. "Error in Inventor Undo Folder: Please Make Correction" any ways to fix this so i can get back to work. and i should add that i am not a computer genius im a furniture designer. please help me out here
16 REPLIES 16
Message 2 of 17
Let's start with your system specifications See this for what is needed:
http://teknigroup.com/support/Inventor/Howto.html
Something else to check (if you can get this far. Open Inventor, go to tools >> Application Options without opening a file:
What do you see here under the general tab?
Message 3 of 17
like i said ive been running this program since it came out with no problems. and nothing has changed on my computer as far as system requirements go
Message 4 of 17
Good luck finding an answer without providing information that is needed.
Message 5 of 17
Hochenauer
I did a search in the source code for Inventor. You should see a dialog, not just a Message box.
The Dialog should give additional information to fix the problem:
Current Undo Folder:
Undo Folder Status:
In order to help you with this issue, it would be best if you could post a screenshot of this dialog here.
regards,
Gerald
Gerald Hochenauer(gerald.hochenauer@autodesk.com)
Inventor Principal Software Engineer
Manufacturing Group
Autodesk, Inc.
Gerald Hochenauer
Senior Principal Engineer, Inventor
Autodesk, Inc.
Message 6 of 17
in reply to: Hochenauer
No worries guy I fixed it myself. Thanks for tryi g to help.
Message 7 of 17
would mind providing the solution, for the next person that finds your thread while searching for the same issue.
thanks
Message 8 of 17
Hochenauer
Please mark the thread as fixed then - no use spending time if there is no further need for help.
Thanks!
Gerald Hochenauer
Autodesk, Inc.
Message 9 of 17
Yes Dash1982,
I agree with this question, can you post the solution because I got the same error on a fresh installation of AutoCADInventor and I have  no idea how to solve this problem. I'd like to prevent that our users get this message
If possible I would like to change the path to a location where All Users have acces (for instance d:\Undo) but where can I configure this setting?
Best regards,
Message 10 of 17
I am having this problem in our school district.  I believe it is related to roaming profiles.  I would like to know how to set the path for the undo folder to a place everyone will have access to.  Can anyone help?
Message 11 of 17
Ktelang
I am experiencing the same problem for Inventor 2013
Please can anybody help.
PS
Mr. dash1982, The discussion forums are not only the place to take
but give as well. Its a give and take of ideas and help each other
Its my understanding - "That knowledge is the only thing which increases by sharing/giving"
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
Message 12 of 17
Ktelang
in reply to: Ktelang
I dont think this can be a solution after reading through other thread but for me with windows 7 64 bit
Inventor 2013 , I rebooted and it did the trick
Hope that might help someone else
Message 13 of 17
Hi there,
I am getting the same error on Inventor 2013. I did not update anything and started getting this error. i also rebooted my system but no luck.
Please help...
Message 14 of 17
Ktelang
I recently found that if your C: drive (Where ever your Inventor Installation is) is out of memory
then you experience that problem. Hope that helps
Message 15 of 17
StevenTalaga5940
Yep, that was my problem. Thanks.
Hard drive full.  Inventor 2013, Windows 7.  Deleted some junk then Inventor was able to open again.
Message 16 of 17
in reply to: StevenTalaga5940
Yes I agree.
If you have the same problem just delete some files from your PC and Inventor will start working again.
Message 17 of 17
The solution is to make more free space on disc where Inventor was being installed 🙂 or change a path to another disc location.
Best regards,
Maciej Bajor
