Inventor General Discussion
Valued Mentor
Ktelang
Message 11 of 17 (2,306 Views)
Re: cant open inventor 2011 undo folder message
08-15-2012 07:42 AM in reply to: jane.hokans
I am experiencing the same problem for Inventor 2013
Please can anybody help.
PS
Mr. dash1982, The discussion forums are not only the place to take
but give as well. Its a give and take of ideas and help each other
Its my understanding - "That knowledge is the only thing which increases by sharing/giving"
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
Valued Mentor
Ktelang
Message 12 of 17 (2,300 Views)
08-15-2012 08:05 AM in reply to: Ktelang
I dont think this can be a solution after reading through other thread but for me with windows 7 64 bit
Inventor 2013 , I rebooted and it did the trick
Hope that might help someone else
Active Contributor
rthakare
Message 13 of 17 (2,217 Views)
09-25-2012 01:55 PM in reply to: Ktelang
Hi there,
I am getting the same error on Inventor 2013. I did not update anything and started getting this error. i also rebooted my system but no luck.
Please help...
Valued Mentor
Ktelang
Message 14 of 17 (2,211 Views)
09-25-2012 03:06 PM in reply to: rthakare
I recently found that if your C: drive (Where ever your Inventor Installation is) is out of memory
then you experience that problem. Hope that helps
New Member
StevenTalaga5940
Message 15 of 17 (2,172 Views)
Re: cant open inventor 2011 (& 2013) undo folder message
10-10-2012 04:03 PM in reply to: Ktelang
Yep, that was my problem. Thanks.
Hard drive full.  Inventor 2013, Windows 7.  Deleted some junk then Inventor was able to open again.
New Member
j.m.bielecki
Message 16 of 17 (1,312 Views)
11-16-2013 11:24 PM in reply to: StevenTalaga5940
Yes I agree.
If you have the same problem just delete some files from your PC and Inventor will start working again.
New Member
Macko131
Message 17 of 17 (1,180 Views)
02-05-2014 03:00 AM in reply to: jane.hokans
The solution is to make more free space on disc where Inventor was being installed :smileyhappy: or change a path to another disc location.
Best regards,
Maciej Bajor
