I made component and wan't to move it up (along z axis), but i can't. I can move it along y and x axis, but not z
Solved by CCarreiras. Go to Solution.
If this is a component by itself as an IPT, I would say that the primary sketch in not fully constrained if it can be move in the X and Y directions. Sounds like this is the plane that the sketch is on. The Z direction then would be your depth of the extrusion. It's placed on the XY work plane and can't move up off it.
You could post the offending part here.
