Inventor Forum
cant move compenent along z axis
4 REPLIES 4
1866 Views, 4 Replies
I made component and wan't to move it up (along z axis), but i can't. I can move it along y and x axis, but not z
4 REPLIES 4
blair
If this is a component by itself as an IPT, I would say that the primary sketch in not fully constrained if it can be move in the X and Y directions. Sounds like this is the plane that the sketch is on. The Z direction then would be your depth of the extrusion. It's placed on the XY work plane and can't move up off it.
You could post the offending part here.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
in reply to: blair
Yes component is saved as an ipt file.
It looks like this:
http://www.fotosik.pl/pokaz_obrazek/e00b5f9e9e24f078.html
green part is component that i want to move
CCarreiras
Hi!
Maybe you have a mate Constrain between th egreen element and one of the others. Open the constrains in the Inventor browser and verify that.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
in reply to: CCarreiras
yes that was the problem, thanks
