hi,
unable to select an edge in the drawing view to create a general dimension.
Check your selection filters for part, edge, sketch, custom...etc.make sure nothing is filtered off
Also check that the view has been placed perfectly square.
1) Check selection (edge, part,etc)
2) Adjust view cube or custom view to perfect normal plane
3) Delete view and just create new view
4) Create new drawing set (.idw/ .dwg) and draw there, if no problem, then copy that sheet and paste into your working drawing set
Just saying.
