Inventor Forum
Cannot save idw files as pdf ... anymore
17 REPLIES 17
Message 1 of 18
PaulMagnard
1459 Views, 17 Replies
I am facing a problem I cannot find how to overcome with Autodesk Inventor 2014.
When I click on the menu, then "Export" and "PDF", autodesk don't offer me the possibility to use the pdf extension in "Save as type" window. And if I add manually the extension ".pdf" at the end of the File Name, then click on save, I get an error message saying :
"Cannot save the document with the specified extension (it is not the right type). Type a different extension for the document you want to save, or do not enter an extension."
The wierdest thing is that I have been exporting hundreds of .idw drawings this way for a month now. Everything went perfectly until today. I tryed to repeat this operation with drawings I had already exported to pdf format a week ago, but now it does not work anymore.
So my Autodesk software cannot create anymore pdf from a .idw drawing but I can't find the reason why since nothing have changed on my computer since last time I exported one to a pdf.
I would appreciate a lot if someone could help me finding a solution.
Thanks in advance,
Paul
Tags (3)
17 REPLIES 17
Message 2 of 18
mcgyvr
in reply to: PaulMagnard
Can you try logging in as a different admin user on your computer and try it?
If that works maybe try this..
http://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcarticl...
Message 3 of 18
Have you tried rebooting?
Message 4 of 18
PaulMagnard
in reply to: mcgyvr
I have tried with other user accounts but it did not work on them
either. However, I know someone else connected to my computer on another
account since last time I (successfully) export a drawing to pdf
format. I will try to see what it gives on his user account.
I have tried the first method suggested in the link you gave me anyway.
But when I type "unregister" after the pathway to Inventor.exe, an error
message stating that the pathway is invalid is returned on the dialog
box. And I have checked that the pathway I typed is correct.
Message 5 of 18
PaulMagnard
Of course ^^
Message 6 of 18
mcgyvr
Have you just tried a repair install of Inventor?
Message 7 of 18
PaulMagnard
in reply to: mcgyvr
Yes, I have also done it but it yielded no results ...
Message 8 of 18
Paul-Mason
Have you tried "EXPORT TO PDF"
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Message 9 of 18
mcgyvr
in reply to: Paul-Mason
Did you read the second sentence of the original post?
Message 10 of 18
PaulMagnard
Actually,that is the issue. That was how I used to save my files as pdf one
week ago, when it worked. But now it doesn't anymore.
Message 11 of 18
blair
Check on your system for any Windows Updates or any other changes to your system from the time when it worked and and quit working.
Start>Control Panel>Programs and Features>View Installed Updates.
Also try using a local directory on your machine, create a TEMP directory on the C:\ drive and see if it works there. Possibly something on your network has changed and you don't have proper privileges to write to the existing directory.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 12 of 18
mcgyvr
in reply to: blair
No idea if this will help or is any part of it but go to tools..options section and press the +Add-Ins button.
Then go to the translators tab and see what it says for "Translator PDF".. maybe try clicking the loaded/unloaded check box and maybe check to ensure the associated DLL file (location section down below) is present..
If all else fails and you don't want to or can't submit a support case to Autodesk I would simply try uninstalling and reinstalling Inventor completely and follow recommended procedures for installing (disable UAC/AV/Firewall,etc..)
Message 13 of 18
johnsonshiue
Hi! Could you take a look at the Add-In loading status? Go to Tools -> Add-Ins -> Translators -> Translator: PDF. Is it loaded?
Thanks!
Software Test Engineer
Message 14 of 18
mcgyvr
in reply to: johnsonshiue
Thanks!
Cool.. guess I was on the right track with my last post..
Message 15 of 18
Paul-Mason
in reply to: mcgyvr
What PDF creator program are you using ?
Inventor 2023 Pro
HP Z420 workstation
Message 16 of 18
mcgyvr
The one thats supposedly built into inventor..
Are you reading a different post from the rest of us or something? Your responses seem to be goofy today..
Message 17 of 18
PaulMagnard
I have checked the PDF translator, and it is loaded "On demand" which
shouldn't be a problem. Nevertheless, I ticked the box "Loaded\Unloaded" to
make sure it is loaded (it is written next to Translator : PDF in the
column "Load Behaviour"), but it still doesn't work.
However I think that we are on the right way, because the location of the
"Translator: PDF" is the following
C:\Program Files\Autodesk\Inventor 2014\Bin\DWFOut.dll
But I checked that DWFOut.dll did not exist in the Bin directory. I guess
it must have been removed or renamed, causing my drawings not to be PDF
exportable anymore.
Do you know what should be file (and its location) corresponding to the PDF
Translator ? If it has been deleted, do you know how I can get one? And if
the Location name is wrong, do you know how to change it? Because in the
Add-Ins Manager panel, one can see the Location of the translator but not
change it.
Thanks !
Message 18 of 18
mcgyvr
exportable anymore.
change it.
Thanks !
It should be there..
Here is a copy from my 2014 version.. Unzip and stick it there and see if it works..
(attached)
