Join Date: 2006-04 Posts: 1 | I am still new to Autodesk Inventor. I have been working my way through several tutorials. The problem that I am having is I cannot record a driven constraint. When I try to record a driven angular constraint with the default settings I get the message “The file C:\\\*.wmv could not be opened.” I made sure that I was in the active project file location. When I try to record a driven angular constraint to an .avi file using the default Microsoft RLE Compressor Inventor seems to record but I end up with a .avi file of 0 bytes. I have tried to use all the different choices and codec’s but to no avail. I think that my problem started after my latest update. Can anyone tell me where to go to resolve my problem? Yours truly Carl T. |
If you are using Inventor 2012 SP1, try this hotfix. http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17804829&linkID=9242019.
Thank you so much, cadull_rd that was the problem and the hot fix not only fixed the .avi problem but also the .wmv also.
Yours truly
Carl T.
