Inventor General Discussion
Member
kaj.petersen
Message 1 of 4 (1,490 Views)
Cannot read texture image
1490 Views, 3 Replies
11-28-2010 05:25 PM
When I start a new document or open a file in Inventor, I get a pop up saying: "Cannot read texture image C:\Useers\public\Documents\Autodesk\Inventor 2011\Textures\Chrome.dds"
 I moved the whole Autodesk file and changed all paths under settings>files in Inventor. The new path to Chrome.dds is C:\Users\Kaj\Documents\Autodesk\Inventor 2011\Textures\Chrome.dds
 Inventor works fine but the pop up is really annoying. What can I do about it?
Thanks in advance.
Mark_Wigan
Message 2 of 4 (1,465 Views)
Re: Cannot read texture image
11-29-2010 04:07 AM in reply to: kaj.petersen
where did you say you specified the texture file path?
the setting i know of from memory is found under application options, colours... filename. if you changed it there is it still doing it?
best regards,
- Mark
PDSU 2014 Windows 7, 64bit. (please consider Kudos or Tag as Solved if your issue is sorted)
Member
kaj.petersen
Message 3 of 4 (1,447 Views)
11-29-2010 02:24 PM in reply to: kaj.petersen
I didn't see that one, thank you very much!
New Member
mattjoe98
Message 4 of 4 (846 Views)
11-14-2012 02:10 PM in reply to: Mark_Wigan
Can you show me how to do that? I'm constantly experiencing an issue where I keep recieving a message stating "Cannot read texture image"
