Solved by mcgyvr. Go to Solution.
I think you have to then go down and check "include" for that sketch.
Can you post the part?
Is it an ipart? or anything else "special" about it.
Can you try it with another "generic" part if you can't post that?
Does it work if you do try it with another part?
Have you updated Inventor?
It works just fine here.
@conbuc wrote:
After playing around with a basic block. It appears that "get model sketches" only works on a view that is normal to the sketch plane. This poses a problem as I need the sketch to appear in the drawing view but the sketch is not normal to the drawing view. Does anyone know if there is a work around for this?
Might help to describe what your "sketch" actually is and what you need it to accomplish.. But yes it must be normal to the view.
I do silkscreening and simply extrude the text so it will show up in all views.
