iPart factory created & published OK, but when attempting to "Generate Files" from iPart table, the Generate Files entry is grayed out.
Is it because the part is already published?
What version are you running?
Can you post this file to look at?
After you have published the files to the CC, can you extract each member form the CC?
Not sure why you need to generate the files after you have published them. Not really seeing why it is necessary.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Hi! Edit the author table and check if there is any column highlighted in blue. That means the column is a custom column whose value can be entered by the user on placement. Also "Generate Files" cannot generate such member.
Please share the iPart factory here or send it to me directly johnson.shiue@autodesk.com. I can take a quick look to see why "Generate Files" does not work.
Many thanks!
I am having a different issue. The "generate files" is able to get clicked, but it will not generate the member and produces the attached error. The I-Table is working, the geometry creates what I need correctly; there are no errors in the feature tree or table. But something is causing this hang up and I can't generate any files.
Hi! The error indicates that certain features in the particular configuration fail to compute. Please share the file here or send it to me directly johnson.shiue@autodesk.com. I can help take a look to understand the behavior better.
Many thanks!
Hi, hoping you are willing to take a look at my ipart. Everything looks as though it should work. I can cycle through all of the part variations, but can't get the table to generate the files. Thank you in advance! Dave
UPDATE: I figured out a fix for my files. I deleted all the previously generated files and then regenerated the files. Everything seems to be back to normal.
