Inventor Forum
Cannot extend
9 REPLIES 9
Message 1 of 10
tmccar
1853 Views, 9 Replies
Cannot extend
When sketching on the face of a solid, using the projected geometry of the edge, I get the error message "cannot extend a curve that is reference geometry" when trying to extend the line.
9 REPLIES 9
Message 2 of 10
blair
in reply to: tmccar
Can you post a screen capture or attached the offending file.
Delta Tau Chi ΔΤΧ
Message 3 of 10
JDMather
in reply to: tmccar
@tmccar wrote:
.... using the projected geometry of the edge, ..."cannot extend a curve that is reference geometry" when trying to extend the line.
Projected geometry is what it is.  You would need to Break Link the geometry if you want to edit it.
If it is just a line (and not a curve (understanding that in math a line is just a special curve)) I would simply turn it to construction and trace overtop of the projected geometry (I always do this in all cases).  That way if I make a significant change earlier in the history my entire part doesn't "go sick", only minor bits of sick geometry to fix.
Message 4 of 10
tmccar
in reply to: JDMather
I have tried the construction option, but I still can't extend.
Message 5 of 10
JDMather
in reply to: tmccar
You are constrained to endpoints (and where did you intend to extend to).
Message 6 of 10
tmccar
I want to extend them to each other (to the apex).
Message 7 of 10
WHolzwarth
in reply to: tmccar
IMO, you should use separate lines with colinear constraints.
Walter
Walter Holzwarth
Message 8 of 10
Hi tmccar,
Generally speaking I think the wh's collinear constraint approach is the best approach, but attached is an alternate method.
I hope this helps.
Curtis
Message 9 of 10
tmccar
in reply to: Curtis_Waguespack
Yes, the collinear approach works great, but thanks for the alternative.
Message 10 of 10
Curtis, I like your way. No sketching and constraining is needed with your solution for this special case.
Walter Holzwarth
