Inventor Forum
Cannot extend member
10 REPLIES 10
Message 1 of 11
Anthony
596 Views, 10 Replies
I need to close a gap between one frame member and another, I have tried using the trim / extend function however this does not work. The members are 25x25x3 SHS, please see attached screen shot which shows the issue. Thank you.
Inventor 2013 SP2
Product Design Suite Ultimate 2013
64-bit HP Z400, Intel Xeon W3550 3.07GHz
12.0GB RAM, ATI FirePro V4800 (FireGL)
Anthony Goodwin ~ Cad Manager/Senior Designer
Autodesk Inventor Professional 2013 SP2 64-Bit Edition
Windows 7 HP Z400, Intel Xeon W3550 3.07GHz
10 REPLIES 10
Message 2 of 11
Cadmanto
in reply to: Anthony
Anthony,
Are you using frame generator?  Are you saying that you cannot change the length of the member and trim it?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 11
Anthony
in reply to: Cadmanto
Hi, I am not using frame generator, the members are added from the content centre and constrained in place, I am able to change the size of the members placed through content centre.
Message 4 of 11
Cadmanto
Have you tried making the member a little longer so it extends past the cross member then using this trim tool, or any of the other frame tools?
Best Regards,
Scott McFadden
Message 5 of 11
cbenner
Scott, will the frame tools work on members placed NOT using Frame Generator?
Message 6 of 11
Anthony
in reply to: cbenner
Thanks for the replies, as pointed out the frame tools do not seem to work on members not placed with FG, as I have placed these directly from CC, bit of a shame, is there another way to use trim, extend etc. on these parts ?
Message 7 of 11
Cadmanto
Chris,
I guess that's what happens when you assume.  It made sense to me that they would work.
The good news is it gave me the makings for an idea.
http://forums.autodesk.com/t5/Inventor-IdeaStation/Frame-Tools-Should-work-outside-of-Frame-Generato...
Sorry, Anthony.  The only suggestion I can make at this point is if you can use the FG then do it.  Then you will be able to use the frame tools.
Best Regards,
Scott McFadden
Message 8 of 11
Anthony
Thanks for the advice, real shame the tools aren't available outside of FG but great to see your post requesting this functionality. Smiley Happy
Message 9 of 11
Cadmanto
No problem.  Wish I could offer something better.
Like I said earlier I assumed the frame tools worked for your application as well.  Kind of limiting if you ask me that they only work with FG.
Hopefully the idea will get enough votes to grab their attention.  Smiley Happy
Best Regards,
Scott McFadden
Message 10 of 11
cbenner
Message 11 of 11
BLHDrafting
Lengthen the member the amount you need to make it touch the rail, then add a chamfer to make it look like it is 'trimmed' to the rail.
In the long run using Frame Generator is youyr best bet.
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
