I need to close a gap between one frame member and another, I have tried using the trim / extend function however this does not work. The members are 25x25x3 SHS, please see attached screen shot which shows the issue. Thank you.
Inventor 2013 SP2
Product Design Suite Ultimate 2013
64-bit HP Z400, Intel Xeon W3550 3.07GHz
12.0GB RAM, ATI FirePro V4800 (FireGL)
Anthony,
Are you using frame generator? Are you saying that you cannot change the length of the member and trim it?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Hi, I am not using frame generator, the members are added from the content centre and constrained in place, I am able to change the size of the members placed through content centre.
Have you tried making the member a little longer so it extends past the cross member then using this trim tool, or any of the other frame tools?
@Cadmanto wrote:Have you tried making the member a little longer so it extends past the cross member then using this trim tool, or any of the other frame tools?
Scott, will the frame tools work on members placed NOT using Frame Generator?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thanks for the replies, as pointed out the frame tools do not seem to work on members not placed with FG, as I have placed these directly from CC, bit of a shame, is there another way to use trim, extend etc. on these parts ?
Chris,
I guess that's what happens when you assume. It made sense to me that they would work.
The good news is it gave me the makings for an idea.
Sorry, Anthony. The only suggestion I can make at this point is if you can use the FG then do it. Then you will be able to use the frame tools.
Thanks for the advice, real shame the tools aren't available outside of FG but great to see your post requesting this functionality.
No problem. Wish I could offer something better.
Like I said earlier I assumed the frame tools worked for your application as well. Kind of limiting if you ask me that they only work with FG.
Hopefully the idea will get enough votes to grab their attention.
@Cadmanto wrote:Chris,
On my way there now.....
Chris Benner
Lengthen the member the amount you need to make it touch the rail, then add a chamfer to make it look like it is 'trimmed' to the rail.
In the long run using Frame Generator is youyr best bet.
