Inventor General Discussion
Active Contributor
GroulsM
Message 21 of 31 (1,499 Views)
Re: Cannot exit IV 2012, hangs on exit
12-28-2011 08:09 AM in reply to: VinodBalasubramanian
if you run into this problem,
go to the add-in manager, right click and select show hidden, search for Simulation: Optimization and uncheck "Automatic start"
We had the same problem here with a slow internet connection
yuliy.finkelsteyn
Message 22 of 31 (1,446 Views)
01-17-2012 03:02 AM in reply to: GroulsM
we have the same issue on close.  Procmon shows that inventor.exe tryes to asstabileshed Internet connection to s3-1-w.amazonaws.com
I think this issue is reliable to Cloud Optimization dialog that does not appers.... Maybe Flash issue?
I will try to install Flash and give you some Update.
Product Support
Message 23 of 31 (1,411 Views)
01-19-2012 08:07 PM in reply to: yuliy.finkelsteyn
Hi All,
Currently this is the only workaround for this problem.
Go to Start -> Run -> Regedit (to launch the registry editor)
Set the registry key “HKEY_CURRENT_USER\Software\Autodesk\Inventor\Current Version\OptimizationUpdateNotified” to 1
This of course prevents the automatic installation of Inventor Optimization.
If you are still interested in working with Inventor Optimization, you can download and install Optimization manually from Autodesk Subscription center.
Hope it helps.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Vinod Balasubramanian
yuliy.finkelsteyn
Message 24 of 31 (1,395 Views)
01-20-2012 02:24 AM in reply to: GroulsM
Hi All,
another workaround is to block Inventor.exe to use Internet Connection in your firewall. (Windows /other)
Regards
Yuliy
Active Contributor
khosking
Message 25 of 31 (1,255 Views)
02-14-2012 07:10 PM in reply to: GroulsM
Hey peoples,
I just reviewed the same problem for one of my clients just now, where Inventor failed to close. The first and only thing I did was engage Inventor Application Options --> Hardware Tab --> "Compatibility Mode" and this seems to have fixed ths issue. I noted that this user was running a Radeon video card, which unfortunately doesn't carry Autodesk certification when reviewing this site;
http://www.autodesk.com/graphics-hardware
But regardless, switching Inventor to Compatibility Mode seems to have done the trick.
MariaManuela
Message 26 of 31 (1,243 Views)
02-15-2012 04:38 AM in reply to: khosking
http://forums.autodesk.com/t5/Autodesk-Inventor/Inventor-2012-does-not-close/m-p/3324593/highlight/t...
"The answer is that Inventor Optimization Update requires 15-20 minutes for downloads and does not allow to close the Inventor 2012 window.
The problem is solved, thanks.
Andrew."
Maria Manuela Pinho
Application Specialist
Cadtech / Asidek - Autodesk Gold Partner
Autodesk Inventor Professional 2015 | Lenovo W520
Hidayah
Message 27 of 31 (1,135 Views)
03-04-2012 11:11 PM in reply to: m.granata
I have this problem also, but not my PC, they try to install inventor but when run can't close after that. They also don't have the inventor Optimization update in the registry. What is the main problem of this? How to close it?
MariaManuela
Message 28 of 31 (1,124 Views)
03-05-2012 03:16 AM in reply to: Hidayah
Are you a Autodesk Subscription customer?
If yes, force the Autodesk Optimization installation (+/- 97 MB because contain Inventor 2012 Sp1)
http://usa.autodesk.com/adsk/servlet/pc/index?id=17796310&siteID=123112
"If you are a PrDS user the Optimization patch will be downloaded automatically once you launch Inventor, the downloading location is the folder " %Temp%", the time of the downloading depends on your network speed, when the downloading is finished a automatic prompt message dialog will be shown in Inventor, and Optimization patch named "centaurupdate.exe" will be in folder " %Temp%".
Maria Manuela Pinho
MikahB
Message 29 of 31 (1,117 Views)
03-05-2012 04:54 AM in reply to: MariaManuela
It seems like the solution options have been laid out several times  now in this thread, which is good.  It is pretty aggravating to me that Autodesk would build in a download like this with no indication of what's going on, no easy way to turn it off, etc.  I literally spent 4 hours trying to "solve" this "problem" because my Internet connection is slow, and I have to pay for usage.  If I had only known what was going on, it would've been an easy fix.
Mikah Barnett
All Angles Design
Product Design Suite Ultimate 2014
Windows 7 Professional x64
Intel i7-3770k @ 4.5GHz
32GB DDR3-2400 RAM
GeForce GTX 670 4GB
MariaManuela
Message 30 of 31 (1,114 Views)
03-05-2012 04:59 AM in reply to: MikahB
I fully agree
And to realize what happened i spend hours and hours searching on internet.
Maria Manuela Pinho
