I am trying to change the path of the workspace in the project file for Inventor however the "edit" oprion is greyed out and I cannot do this.
This needs changing to match the project location. Please can anyone advise ? Thank you
Anthony Goodwin ~ Cad Manager
Autodesk Inventor Professional 2013 SP2 64-Bit Edition
Windows 7 HP Z400, Intel Xeon W3550 3.07GHz
12.0GB RAM, ATI FirePro V4800 (FireGL)
The screen capture you posted indicates that the project file is marked read-only.
Try changing it in WIndows Explorer to not read-only and try again.
Great, thanks for your input, I didn't spot that
Anthony
I have the same problem as this but the answer won't work for me.
I have looked in Windows explorer and it isn't set to read only.
Please see the attached screenshot, any ideas?
Thanks in advance.
Hi! This is a Vault project. I guess you will need to check it out from the Vault and then you can edit.
Many thanks!
