Here's a better way to create the sketch. 2008 file is attached...
1. Center your sketch about the part origin.
2. Create 2 offset horizontal construction lines with a vertical constraint
between the origin point and the midpoint of the construction lines.
One construction line will be used to control the length of the arc, and the
other one will control the offset from the origin point.
3. Dimension the first construction line to .064
4. create the arc between the two endpoints of the construction line
5. Make the second construction line tangent to the arc.
6. Use circular pattern in the sketch panel to pattern the arc 4 times about
the part origin point.
7. Create a circle with a diameter of .005 near each corner. Alternatively
you might create a construction line between each pair of arc endpoints, and
then use the midpoint of the construction line and the endpoint of the arc
to create each circle.
8. Apply 2 tangent constraints to each circle and the adjoining arcs
9. Trim all four circles.
Dennis Jeffrey, AICE, MICE
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP2, AIP 2008
HP Pavillion Zv5000 (Modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
http://www.design-excellence.com
wrote in message news:5627804@discussion.autodesk.com...
Try this file
