I am probably missing something obvious but for some reason I cannot constrain to the surfaces of this part - only the origin planes. Could somebody please take a look and let me know what you discover?
Inventor 2011 part
Works here in 2012?
Shouldn't this part be uniform thickness?
If so, wouldn't Contoured Flange be a lot easier?
Hi JD,
Thanks for checking in 2012 - could somebody also check in 2011? If it works then I will upload the assembly as I cannot get it to constrain by surface at all. I will also upload a video as it seems unbelievable.
(JD - Contour flange would be much simpler but there was a reason for doing it this way and there is also a reason why the part does not have uniform thickness - thanks though.)
Rob
I am on my 2011 machine today and I get errors on the "outside" faces of the C (except for the ends). Constraints work on the "inside" faces and ends.
I'll have to check again in 2012 now that I see the constraint error.
Thanks for confirming. I may send this part to Autodesk as it created a lot of time and grief for me in my assembly as it took forever to troubleshoot my constraint errors. Who would have thought that a part with flat sides cannot be constrained too? Or maybe somebody from Autodesk could take a look from here.
Rob
Seemingly it works well after re-create thincken in Inventor 2011 and 2012. Maybe you can try it on 2011 or 2012 version.
