Inventor General Discussion
Distinguished Contributor
Orest_iy
Message 1 of 8 (129 Views)
Cannot alter any Dimension and Constraint in the fully constrained sketch
129 Views, 7 Replies
10-04-2013 03:37 AM
Hello
I have a simple part.
The problem is I cannot change any Dimension to Driven Dimension and cannot delete any Dimension and Constraint, see video link
http://screencast.com/t/4xOD3pggR2YK
I have copied the sketch and created the new part but once it finished the problem came back again. Please advise what is wrong. Other parts are ok.
Part IPT is attached.
Best regards,
Orest Yavtushenko
blair
Message 2 of 8 (105 Views)
Re: Cannot alter any Dimension and Constraint in the fully constrained sketch
10-04-2013 08:43 AM in reply to: Orest_iy
Works fine here, just double click on the dimension to change. Not sure why you are selecting the "Dimension" command.
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 340.52
SpacePilot Pro 3.17.7, 6.17., 4.11
Delta Tau Chi ΔΤΧ
JDMather
Message 3 of 8 (99 Views)
10-04-2013 08:55 AM in reply to: blair
Blair - I am not at my 2014 machine right now.
Can you click on a dimension and toggle it from Driving to Driven?
Can you delete a constraint?
I get the same error in 2013.
(the file is a 2012 file)
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
Orest_iy
Message 4 of 8 (92 Views)
10-04-2013 09:31 AM in reply to: JDMather
No, here is the point of this problem.
Orest
blair
Message 5 of 8 (91 Views)
10-04-2013 09:32 AM in reply to: JDMather
You had a couple of "Sick" dimensions, one at each end of the sketch referencing the diameter of the body. Deleting them fixed the sketch.
Win7-64
Delta Tau Chi ΔΤΧ
cbenner
Message 6 of 8 (89 Views)
10-04-2013 09:34 AM in reply to: blair
What also helped was deleting the sketched axis, and using the projected origin plane, set to a construction axis.  That and deleting the two sick sketch lines did it for me.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
Orest_iy
Message 7 of 8 (88 Views)
This part is under design as well as all assembly. I wish I can do whatever I want with my part as I do with others but I cannot. I need to alter geometry a bit, not just alter the dimensions.
Orest
Orest_iy
Message 8 of 8 (82 Views)
10-04-2013 09:40 AM in reply to: blair
Hmm, does not work on my sketch. Once I have touched at least one dimesion I must delete all of them until this sketch gets calm as well as touching the constraints.
Orest
