Good morning,
I was wondering if someone could help me. I am new to Inventor, I have Inventor 2014. I bought a book called Mastering Autodesk Inventor 2014 the Autor is Curtis Waguespack. I was following along in Chapter 19 on mold design. I got the part in after clicking on Plastic Parts. After right clicking, and clicked done, I then clicked on "Select Material" (to add material as the book said) and I get a message error see attachment. I did click on the configure Libraries see attachment two. Not sure where to go from here.
Many thanks,
John
Solved by beltloaderman. Go to Solution.
Solved by JDMather. Go to Solution.
Have you installed Service Packs 1 and 2 and Update 3?
Are you running on stand-alone license or on network license?
Good Afternoon JD,
Thanks so much for getting back with me. I just downloaded and installed service pack 2, but I did not see and update for 3, can you point me in the right place. To answer your other question, I am running a stand-alone license. When I did install service pack 2 I was able to click on "select Material" and I am now able to put material to the mold. I did go back to Communication Center, and it is showing that there is a Product Update available. When I click on the update it still show it for the service pack 2.
Thanks so much,
John
Is your problem solved?
