Inventor Forum
Cannot access the Mold Layout Tab/Ribbon in Autodesk Inventor Pro 2014.
7 REPLIES 7
Message 1 of 8
leaveAlone
4316 Views, 7 Replies
I I Cannot access the Mold Layout Tab/Ribbon in Autodesk Inventor Pro 2014. I have installed all of the Content Libraries and the Inventor Mold Metric Library is available in Content Center.  The mold design (mm).iam file is also not seen in the Templates file. I have opened mold design (mm).iam file found by searching my computer, but the Mold Layout Tab/Ribbon does not appear. I opened up an .ipt file from the Mold Library and the Mold Design Layout tab DOES NOT APPEAR.
Please Help. How can I get the Mold Layout Tab/Ribbon in Autodesk Inventor Pro 2014 to be accessible?
7 REPLIES 7
Message 2 of 8
JoAnn_Hogan
in reply to: leaveAlone
Please just check in the Part environment > Environments Tab > Begin Panel > Create Mold.
Then you will see your Mold Layout tab
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
Message 3 of 8
leaveAlone
in reply to: JoAnn_Hogan
This did not work. I do not see any Part or "Part Environment" I have Environments tab, but under the begin Panel is only Inventor Studio and BIM exchange.
Message 4 of 8
JDMather
Clean Install
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17955581&linkID=9240617
You are going to have to start supplying a lot more information if you want to solve this problem.
I would be very curious why your install does not show default templates.
OS?
Screen captures?
New problem? Did it use to work?
New install, it never worked?
Installed with anti-virus an UAC off?
Message 5 of 8
JDMather
in reply to: JDMather
... and out of curiosity - what your assembly environment screen does look like when opening the Mold.iam  (I should say, File New, not Open).
Message 6 of 8
JDMather
@leaveAlone wrote:
 The mold design (mm).iam file is also not seen in the Templates file. I have opened mold design (mm).iam file found by searching my computer.
Did you copy the template file to the correct Templates location?
Did you Open or did you File>New?
What is the path to your Templates in your active Project (*.ipj)?
Message 7 of 8
JoAnn_Hogan
Are you sure you have Inventor Professional?
Jo - Ann
Message 8 of 8
hi
i have same problem with inventor 2013
inventor mold imperial and inventor mold meusburger is red only i have both of them
mold desing in add-in 2013 exist
but in environment i can see creat mold desing
and on ribbon bar  i can not see mold layout or mold assembly
what should i do?
please help
