Inventor Forum
Can you move the detail leader in a drawing?
5 REPLIES 5
dpsmith85
1332 Views, 5 Replies
When I make a detail in a drawing sometimes the leader gets in the way because it is always pointing to the same spot at the top of the detail.  Is there anyway to move this so it points mabe to the side or bottom of the detail?
5 REPLIES 5
macflirty
in reply to: dpsmith85
Hi dpsmith85,
The detail leader can be easily moved by hovering on top of the Detail View Name (e.g "A" ) then pick wait for the moved icon and  drag to left or right, top or bottom.  The arrow will follow where the View name will be placed.  If this is not what your looking for better show some snapshot for others to help you.
Cheers,
macflirty
dpsmith85
I dont know if I was following exactly what you were saying so I've attached a pic for more clarification.  It's showing the original placement of the leader and then it shows where I moved the leader to.  My goal is to get the arrowhead to move out of the way instead of across the model.  Thanks for the response though.
macflirty
To add up from my previous reply if it's an existing leader view name.
1) RMB the Detail View Name ("A") then uncheck "Leader".
2) Move Detail View Name to your desired location.
3) RMB again and then Check the "Leader".
You can't move the arrow leader explained if the leader is checked.  Uncheck first then move.
dpsmith85
PERFECT!! Thanks for the help, it's nice to get stuff like that figured out.
macflirty
Please click "Accept as Solution" if my previous response answers your question.
I'm glad to help. Smiley Wink
Cheers!
macflirty
