Inventor Forum
Can you edit adsklib files directly?
4 REPLIES 4
mslosar
3649 Views, 4 Replies
it used to be that EVERYTHING was xml based so you could simply pull up a file in excel make some changes, save it, and use it in Inventor again. Adsklib files don't seem to fit that scheme. Is there a way to edit them directly? I've got a custom list of 100 or so materials that i'd like to edit some physical properties for calcs and whatnot, but i do not want to have to open the material library, then every time double click the material to open in the edit, go to the right section and find the correct value to edit. I nice long list in a spreadsheet type view would save loads of time there.
Is there any option for that or we stuck with the long/slow way?
4 REPLIES 4
in reply to: mslosar
Did you solve it ? I have similar problem.
Tags (1)
blair
in reply to: 308449190
For XML files, it's easier just to use the Microsoft XML Notepad (free from Microsoft, just search their website).
The ADSKLIB is proprietary and there is no easy way other than through Inventor, one line at at time, unfortunately.
Delta Tau Chi ΔΤΧ
F.Goncalves
hi! did you got any solution for this?
I have the same problem...
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
F.Goncalves
mitcham_boy
in reply to: F.Goncalves
No I didn't.
Regards
Dan
________________________________
This email and any attached files are confidential and copyright protected. If you are not the addressee, any dissemination of this communication is strictly prohibited. Unless otherwise expressly agreed in writing, nothing stated in this communication shall be legally binding.
The ultimate parent company of the Atkins Group is WS Atkins plc. Registered in England No. 1885586. Registered Office Woodcote Grove, Ashley Road, Epsom, Surrey KT18 5BW. A list of wholly owned Atkins Group companies registered in the United Kingdom and locations around the world can be found at http://www.atkinsglobal.com/site-services/group-company-registration-details
Consider the environment. Please don't print this e-mail unless you really need to.
