Inventor Forum
CAN THIS BE FLATTENED?
5 REPLIES 5
JimSteinmeyer
724 Views, 5 Replies
I am dealing with some leagacy parts that I need to turn into sheet metal and modify. Is there a way to flatten this part? I have attempted to convert to sheet metal and create a flat pattern but it will not flatten. I have also attempted to unfold but that does not work either? I could bring in a new dxf and start over, but if this could be flattened it may be faster. Can someone offer suggestions as to how to flatten?
inventor 12
Thank you
Jim s
Jim
Inventor Premium 2013 SP1.1
Vault 2013- plain vanilla version
HP G71 notebook
celeron cpu w\ 4gb RAM and 64 bit system
Win 7 home premium
Ya, my boss has me running my personal machine at work.
5 REPLIES 5
mcgyvr
in reply to: JimSteinmeyer
As modeled NO. Because the material/sections near the middle (those 4 triangles) require deformation(elongation/stretching) of the material in multiple directions which is not supported in Inventor/unfolding.. This is a stamped part not a press brake part.
M.Peppel
Hi Jim,
please find the unfolded part attached. A friend of mine (he owns Logopress 3) unfolded it for you.
 Regards
 Matthias
Nihil Ex Nihilo
JimSteinmeyer
in reply to: M.Peppel
Methias,
Thank you for getting this done, Thank your friend as well. do you know what method he used?
Mcgyvr. thank you for looking at the part. If I were to slit the sides where the lines in the center would that work? I Don't know why I didn't look at that before asking as that is how we cut the part to fold it.
Jim
Jim
HP G71 notebook
Win 7 home premium
JDMather
I think if you cut out those "triangles" you might be able to get it - but not the way you bent the part.  Use sheet metal tools.
industrial
Hi, I'm new to the forums, I want to know a little more of how Logopress in autodes inventor.
I have read on the internet but focuses heavily on soliword, in one of the consultation found a video but falls short. appreciate the help
postscript, my English is a bit sorry for the bad translation
att. Hedwynson Hernandez
