Inventor General Discussion
Distinguished Contributor
6 Kudos
Post 1 of 9
Can't use model sketches within a drawing view sketch?
1119 Views, 8 Replies
04-16-2012 12:13 PM
I can "Get Model Sketch" to make it appear visible in a drawing view. But I can find no way to use these "edges" or "lines" or "entities" or whatever they are, later in a drawing view sketch. No way to project them from Model Sketch to Drawing View sketch. I can attach leaders and dimensions to these Model Sketch entitites but I can find no way to use them in a sketch owned by the drawing view. Am I missing something?
IV2012 SP1
1,706 Kudos
Post 2 of 9
Re: Can't use model sketches within a drawing view sketch?
04-16-2012 12:23 PM in reply to: dick_upton
Hi dick_upton,
Is the sketch parallel to the drawing view? If not the sketch can not be displayed.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
6 Kudos
Post 3 of 9
04-16-2012 01:02 PM in reply to: Curtis_Waguespack
Oh, it displays just fine, I just can't project any of the lines that are displayed into a drawing view sketch. It doesn't to me that they can be used that way.
1,706 Kudos
Post 4 of 9
04-16-2012 01:08 PM in reply to: dick_upton
Hi dick_upton,
Is your sketch associated with the view? Meaning that the sketch was created by selecting the view first and then creating the sketch. If the sketch is not associated to the view, then you can't use it to project geometry.
If you click and drag on the view and the sketch doesn't move with the view, then this is likely the issue. If it does move, then it is associated and there is something else going on.
I hope this helps.
Curtis
2,129 Kudos
Post 5 of 9
04-16-2012 01:20 PM in reply to: dick_upton
I just verified in 2012 that it does not work.
You cannot Project Geometry included model sketches.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
6 Kudos
Post 6 of 9
04-16-2012 01:25 PM in reply to: JDMather
Yes I was just going to say that I can confirm that the sketch is owned by the view, but thanks for the confirmation JD.
Wonder if I'll be waiting 12 years for this fix, like the cancel command.
6 Kudos
Post 7 of 9
04-16-2012 01:28 PM in reply to: dick_upton
Seems to me that Autodesk should be wise enough to use these forums as a simple way to log feature requests. Add a button below Accept As Solution:
- Accept As Solution
- Solution does not exist - Request action by Autodesk.
Could get us away from the snarky "please submit a feature request" replies by the devs.
1,706 Kudos
Post 8 of 9
04-16-2012 01:31 PM in reply to: JDMather
Hi JDMather,
Now that you mention it I don't think it ever worked that way. :smileyembarrassed:
I was thlinking of the model edges requiring an associated sketch to be projected. I just checked in an older version and indeed you can't project model sketches in an associated sketch.
I hope this helps.
Curtis
New Member
0 Kudos
Post 9 of 9
11-22-2012 07:50 AM in reply to: Curtis_Waguespack
