Inventor Forum
Can't Shell my tire
6 REPLIES 6
rebekah_harper
766 Views, 6 Replies
Can't Shell my tire
Hiya all.
I am modeling a tire. I got the tread in using extrusion into and extruded circle.
but I keep getting, use a smaller wall size. I have managed to acheive it before but for some reason it won't let me do it this time.
I have attached the file in the hope some one would be able to assist me.
many thanks
Becky
6 REPLIES 6
admaiora
in reply to: rebekah_harper
Pay attention to the uncontrolled creation of useless Sketches.
In this case instead the Sheel tool i would use a  revolve cut.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
WHolzwarth
This seems to be some work for Autodesk QA.
I tried a Rebuild All with 2015 SP1 Update 1, and failed at Extrusion2.
I ended with a Crash. No CER sent.
Walter
Walter Holzwarth
rebekah_harper
in reply to: WHolzwarth
thankyou for your replies.
I will try the revolve cut once I understand how it works
admittedly I am in short supply of ram so my machine trips over easily.
wilkhui
Hi Becky,
At what thickness are you attempting the shell?
I tried to shell your part at 1mm but this fails - one cause could be the small features on the tread. Can you remember how you achieved the shell in the past? When I attempted the shell at 0.1mm it succeeded with no problems; it was a bit slow but I'd expect that for a shell at this stage of the model.
Would it be more appropriate to shell before modelling a tread? It seems to be the way that they're constructed eventually, here's a picture I found of a tractor tyre cross section:
Separately, this seems to be made in Inventor 2015 without updates. I'd recommend installing Service Pack 1 and then Update 1 for SP1 which can be found here.
Looking forward to hearing back!
Indy
Inderjeet Singh Wilkhu
Product Owner - ASM
rebekah_harper
in reply to: wilkhui
Hiya,
Am getting used to it more and more. The main thing is how to see a part within the mind and breaking it down in stages.
Thank you for the advice. I was aiming for 2 mm. But with what you said, I found it not a problem.
wilkhui
Hi Becky,
I'm glad that you found a way through this, hope the rest of the project goes well!
A fellow forum user with the username -niels- usually posts a thread on Fridays for others to add pictures of their work. It would be great to see pictures of your progress there 🙂
Best wishes,
Indy
Product Owner - ASM
