When I got Inventor Pro 2014 up and running, I went to make a new standard part. I had all of my toolbars, but when I went to draw something, nothing showed up but the dimensions of the line I was making. I even tried loading a part I found online, but all I could see was the same, blank white screen. Any idea as to what I can do to fix this problem?
See attached images for an example of the screen I met when trying to draw or assemble.
System spec's would help.
I would check to see that you are on the most current Microsoft certified drivers for your systems graphics card.
You followed all the installation prerequisites?
In addition to checking your graphics card/driver go to Tools>Application Options>Hardware tab and set on lowest setting.
Reboot
Any difference?
What is your current Tools>Application Options>Colors scheme?
