Inventor Forum
Can't project intersection between two pipes
7 REPLIES 7
Message 1 of 8
mcwap-dvc
2362 Views, 7 Replies
I am having problems with projecting the intersection between two pipes onto a sketch.
I get the error: "Projection of the selected spline edge/curve would result in a degenerate segemtn and cause future modelling problems."
I have attached a screenshot that hopefullly explains it.
Any ideas?
I have a workaround which involves exporting to AutoCAD and then back to inventor but that is quite tedious.
________________________________________________________________
Dell T3500, Win7 Pro 64-bit, Xeon W3520 @2.67GHz, 6GB RAM, Quadro FX580
Inventor Professional 2011 64-bit
Civil 3D 2011 64-bit
7 REPLIES 7
Message 2 of 8
Dennis_Jeffrey
in reply to: mcwap-dvc
I would use the Copy Object command to create surfaces for trimming the parts. I'll see if I can dig up one of my class examples to illustrate.
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
Message 3 of 8
mcwap-dvc
in reply to: Dennis_Jeffrey
I am trying to model a crotchplate, as per the attached picture.
So I need that curve of the intersection projected on the yz plane.
Message 4 of 8
Dennis_Jeffrey
Helps also to post your Inventor version.
Would have been nice to know that... I'd then take a different approach like this:
Message 5 of 8
mcwap-dvc
I use Inventor Professional 2011 64-bit.
Can you explain how you did this? Although I think you have modelled what I would call a wrapper plate. Attached is another view of what I am trying to do.
Message 6 of 8
mcwap-dvc
That should be collar plate.
Message 7 of 8
udayag
It seems that edge projection fails near the end points of the projected curve. To avoid this region I split the larger cylindrical surface using a workplane that was slightly shifted from the midplane. Sketch projection then used the edge of this split surface. Hopefully this approximate solution would work for you.
Udaya Gunasena
Fusion Development
Message 8 of 8
mcwap-dvc
in reply to: udayag
Thanks a lot!
That approximation is close enough for me.
