It was case one. I was designing a very thin contact and it was easiest to
construct as a sketch line surfaced and then thickened. It would have be
useful to be able to pattern this part....
Sean Dotson, PE
http://www.sdotson.com
remove all #s from email
"Glenn" wrote in message
news:68CD3ED95D1BECAFF9EFEE0DE919519E@in.WebX.maYIadrTaRb...
> Sean,
> We have the following two cases for patterning a thicken feature:
> 1. Thickened surface: For example, you have ExtrusionSrf1 and Thicken1.
You
> cannot select either in a pattern command. It's as designed (for now).
> 2. Thickened solid: For example, you have Extrusion1 (solid) and
Thicken1.
> You can only select the Thicken1 as a "secondary selection" (just like
> Fillet) in a pattern command -- primary selection being Extrusion1
(solid).
> NOTE: In general, you can't pattern any kind of surface in Inventor (for
> now).
> Glenn
> Inventor Part Modeling
> "Sean Dotson" wrote in message
> news:BA58E0CDAD706BC2AF9C7B4DDD3563C4@in.WebX.maYIadrTaRb...
> > That's disappointing... bug or as designed?
> > Sean Dotson, PE
