Inventor Forum
Can't pattern a thickened surface
2 REPLIES 2
297 Views, 2 Replies
That's disappointing... bug or as designed?
Sean Dotson, PE
http://www.sdotson.com
remove all #s from email
2 REPLIES 2
Sean,
We have the following two cases for patterning a thicken feature:
1. Thickened surface: For example, you have ExtrusionSrf1 and Thicken1. You
cannot select either in a pattern command. It's as designed (for now).
2. Thickened solid: For example, you have Extrusion1 (solid) and Thicken1.
You can only select the Thicken1 as a "secondary selection" (just like
Fillet) in a pattern command -- primary selection being Extrusion1 (solid).
NOTE: In general, you can't pattern any kind of surface in Inventor (for
now).
Glenn
Inventor Part Modeling
"Sean Dotson" wrote in message
news:BA58E0CDAD706BC2AF9C7B4DDD3563C4@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
It was case one. I was designing a very thin contact and it was easiest to
construct as a sketch line surfaced and then thickened. It would have be
useful to be able to pattern this part....
Sean Dotson, PE
"Glenn" wrote in message
news:68CD3ED95D1BECAFF9EFEE0DE919519E@in.WebX.maYIadrTaRb...
> Sean,
You
Thicken1.
(solid).
> now).
> Glenn
> > Sean Dotson, PE
