Inventor General Discussion
Active Member
shawnyu
Message 1 of 6 (823 Views)
Can't open old version of file from vault.
823 Views, 5 Replies
09-14-2011 12:17 PM
Dear Sirs,
As attached, the open command is greyed out when I want to open an old verson of a file from Vault 2012, somebody can hlep me to solve it?
My system is Window 7 64-bits, Inventor 2012/Vault 2012.
Thank you!
Shawn
Dear Shawn,
you cannot open the previous versions of a model directly from the Vault. You have to Get it locally (Get Check out command) then open it from local copy.
This is to avoid undesired overwrite of local copy with old file versions. With Get command you will have a warning if local copy is newer.
Hope this helps.
Regards
You should not Open files with Vault Explorer.
Select Get/Checkout, which should download the file to your local Workspace, then Open it from your local Workspace.
Mike
Product Support
francesco.tonioni
Message 2 of 6 (802 Views)
Re: Can't open old version of file from vault.
09-14-2011 01:08 PM in reply to: shawnyu
Dear Shawn,
Hope this helps.
Regards
Francesco Tonioni
Support Specialist
Product Support
Mike_Maenpaa
Message 3 of 6 (801 Views)
09-14-2011 01:09 PM in reply to: shawnyu
Mike
Active Member
shawnyu
Message 4 of 6 (777 Views)
09-19-2011 08:51 AM in reply to: francesco.tonioni
Thank you very much, Francesco!
Active Member
shawnyu
Message 5 of 6 (776 Views)
09-19-2011 08:52 AM in reply to: Mike_Maenpaa
Thank you, Mike, I am going to remember the rule./Shawn
New Member
joshuawenzel
Message 6 of 6 (71 Views)
09-09-2014 11:26 AM in reply to: Mike_Maenpaa
Why should you not open files directly from Vault?
